Request for Make Planar / Flatten Filter
  • sam3d
    • 98
    Would there be any scope to add a filter to simply flatten a mesh selection?
    Having options for best fit/average, by edge vertices or even XY/vertical plane would be great
    The main reason is I often want to be able to quickly flatten out areas of walls/ceilings, particularly in corners, where the surfaces are noisy and it'd be great to do this all inside Zephyr.
  • Nedo
    3Dflow Cup 2018 winner
    • 71
    if this works out, then for a square wall you would only need 4 vertices in the end!
    • sam3d
      • 98
      Indeed! In my case i typically work with buildings/outdoor scenes where a simple plane maybe sufficient at times, certainly for the surrounding elements.
      I appreciate that mesh manipulation is beyond the scope of Zephyr but it'd be handy to be able to flatten local areas as a quick fix.
