If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Saw this thread only after cleaning it up from some spam.
You can also use the cut with bounding box tool in zephyr. That will create new polygons from the intersection, creating a clean cut like requested, so you don't need to exit zephyr to achieve that
Hi kafkaf21 - The selection tool selects the mesh polygons which is why you see the jagged edges - It's currently not possible to achieve what you are after in Zephyr.
Us there a way to cut the mesh smoothly?
When I use the selection tool they select the polygons, leaving jagged edges like this: ?
I need to cut it smoothly like this:
If this cannot be done in 3df, can it be done in blender and if yes, what is the best, and easiest way to achieve a smooth cut??
