Images not being stored after extraction from video - new to 3.5
  • nkr
    • Nov 2017
    I had been using 3.302 to successfully extract photos from an mp4 video, and then further process with Zephyr. I recently upgraded to 3.5, and since then I no longer can.
    Extraction "appears" to work as before, and when complete the names of the extracted images show up in the window (but not in the directory). According to the log file (example attached)
    they have been dumped to disk. However, when I press the "next" button, they disappear from the window, and I can no longer proceed. This is running on the same computer, same directories, and same settings. Any suggestions?
    [12:28:10] SysInfo | Cpu: 100.00 %; Disk (C/T): 56026/80649 MB (24623 MB free, 69.47 % used); Memory (C/T): 4156/8117 MB (3961 MB free, 51.20 % used)
    [12:30:10] SysInfo | Cpu: 79.35 %; Disk (C/T): 56063/80649 MB (24586 MB free, 69.51 % used); Memory (C/T): 4210/8117 MB (3907 MB free, 51.87 % used)
    [12:30:45] Workspace saved to C:/Users/nigel/Documents/some-pam.zep
    [12:31:36] Font DefaultRenderingFont using texture size 2048x1024
    [12:31:36] Texture: DefaultRenderingFontTexture: Loading 1 faces(PF_BYTE_LA,2048x1024x1) Internal format is PF_BYTE_LA,2048x1024x1.
    [12:32:01] SysInfo | Cpu: 93.07 %; Disk (C/T): 56163/80649 MB (24486 MB free, 69.64 % used); Memory (C/T): 4111/8117 MB (4006 MB free, 50.65 % used)
    [12:33:53] Extracting frames from C:/Users/nigel/Documents/pam38/pam38.mp4
    [12:34:00] Frame window filled - picking best frame,0 queued, 0 processed
    [12:34:01] SysInfo | Cpu: 100.00 %; Disk (C/T): 55586/80649 MB (25063 MB free, 68.92 % used); Memory (C/T): 4327/8117 MB (3790 MB free, 53.31 % used)
    [12:34:23] Frame window filled - picking best frame,1 queued, 0 processed
    [12:34:45] Frame window filled - picking best frame,2 queued, 0 processed
    [12:35:08] Frame window filled - picking best frame,3 queued, 0 processed
    [12:35:40] Picking best frame from leftover frames...
    [12:36:01] SysInfo | Cpu: 100.00 %; Disk (C/T): 55568/80649 MB (25081 MB free, 68.90 % used); Memory (C/T): 4361/8117 MB (3756 MB free, 53.73 % used)
    [12:36:02] Starting post processing...
    [12:36:03] Dumping frames to disk...
    [12:36:03] Done!
    Hi nkr,
    thank you for reporting it, sorry about your issue!
    i see only four frames at all, which is very unusual. Is that a very short file by chance? Do you think you can share the file with me so i can try to replicate the problem?
    thank you!
    • nkr
      • Nov 2017
      Thanks for the reply. I just extracted fewer images for this final run to make it quicker. Previous runs extracting 49 images took much longer, and I had not kept the log file. I have now tried 3 different mp4 files, all of which used to work with 3.302, and now none of the is working with 3.5. How would you like me to send the mp4 file - it is about 24MB, the other is ~ 40MB.
        Hi Nkr,
        Sorry about the issue and thank you for sharing the data. You can send the video via wetransfer.com and send the link to support@3dflow.net
        As an additional test, can you try to select the desktop or the documents folder (no subdirectory) as output directory?
        Thanks!
        • Nedo
          3Dflow Cup 2018 winner
          • 71
          Hi Roberto, just wanted to share what i expirienced with video extraction, i'm only able to dump to Desktop or any Desktop Folder. Dumping dont work on another drive.
            Thanks for reporting this. Actually I've just checked and I'm able to dump frames without problems in any folder on my machine. Does it write some error in the log?
            • Nedo
              • 71
              Hi Roberto, no errors in the log file, but today i found out why it works sometimes and sometimes not, at least on my machine.
              In the menue "Extract frames from video file" when i chose a folder in the output directory it will not dump pics to it,
              but if i create a new folder from the "Extract frames from video file/Output directory" then it works. So i have to create a new folder
              from inside 3DF Zephyr, then it works for me.
              Nedo
                Thank you for sharing the workaround!
                I would like to investigate further on the problem. Can you tell me an example of output path that doesn't work? Like D:\Test? Does it have trailing slashes at the end of the path? Thanks and Best Wishes!
                • donbert
                  I seem to be having the same problem but am not able to get it to work even when saving to the desktop. Is there any other workarounds that people have found?
                  Here is my log file:
                  [10:02:11] SysInfo | Cpu: 62.52 %; Disk (C/T): 163706/487036 MB (323330 MB free, 33.61 % used); Memory (C/T): 571/16308 MB (4967 MB free, 3.50 % used)
                  [10:02:58] Font DefaultRenderingFont using texture size 2048x1024
                  [10:02:58] Texture: DefaultRenderingFontTexture: Loading 1 faces(PF_BYTE_LA,2048x1024x1) Internal format is PF_BYTE_LA,2048x1024x1.
                  [10:03:47] Extracting frames from C:/Users/donbe/Desktop/Zephyr Temp/01082018193157.MOV
                  [10:03:56] Frame window filled - picking best frame,0 queued, 0 processed
                  [10:04:01] SysInfo | Cpu: 21.16 %; Disk (C/T): 163736/487036 MB (323300 MB free, 33.62 % used); Memory (C/T): 2005/16308 MB (3104 MB free, 12.29 % used)
                  [10:04:09] Frame window filled - picking best frame,1 queued, 0 processed
                  [10:04:22] Frame window filled - picking best frame,2 queued, 0 processed
                  [10:04:35] Frame window filled - picking best frame,3 queued, 0 processed
                  [10:04:48] Frame window filled - picking best frame,4 queued, 0 processed
                  [10:05:01] Frame window filled - picking best frame,5 queued, 0 processed
                  [10:05:14] Frame window filled - picking best frame,6 queued, 0 processed
                  [10:05:28] Frame window filled - picking best frame,7 queued, 0 processed
                  [10:05:43] Frame window filled - picking best frame,8 queued, 0 processed
                  [10:05:58] Frame window filled - picking best frame,9 queued, 0 processed
                  [10:06:01] SysInfo | Cpu: 75.81 %; Disk (C/T): 163762/487036 MB (323274 MB free, 33.62 % used); Memory (C/T): 2232/16308 MB (2605 MB free, 13.69 % used)
                  [10:06:15] Frame window filled - picking best frame,10 queued, 0 processed
                  [10:06:30] Frame window filled - picking best frame,11 queued, 0 processed
                  [10:06:44] Frame window filled - picking best frame,12 queued, 0 processed
                  [10:06:58] Frame window filled - picking best frame,13 queued, 0 processed
                  [10:07:12] Frame window filled - picking best frame,14 queued, 0 processed
                  [10:07:25] Frame window filled - picking best frame,15 queued, 0 processed
                  [10:07:39] Frame window filled - picking best frame,16 queued, 0 processed
                  [10:07:52] Frame window filled - picking best frame,17 queued, 0 processed
                  [10:08:01] SysInfo | Cpu: 25.75 %; Disk (C/T): 164807/487036 MB (322229 MB free, 33.84 % used); Memory (C/T): 1545/16308 MB (3255 MB free, 9.47 % used)
                  [10:08:06] Frame window filled - picking best frame,18 queued, 0 processed
                  [10:08:19] Frame window filled - picking best frame,19 queued, 0 processed
                  [10:08:34] Frame window filled - picking best frame,20 queued, 0 processed
                  [10:08:49] Frame window filled - picking best frame,21 queued, 0 processed
                  [10:09:04] Frame window filled - picking best frame,22 queued, 0 processed
                  [10:09:18] Frame window filled - picking best frame,23 queued, 0 processed
                  [10:09:34] Frame window filled - picking best frame,24 queued, 0 processed
                  [10:09:49] Frame window filled - picking best frame,25 queued, 0 processed
                  [10:10:01] SysInfo | Cpu: 100.00 %; Disk (C/T): 164807/487036 MB (322229 MB free, 33.84 % used); Memory (C/T): 1877/16308 MB (2374 MB free, 11.51 % used)
                  [10:10:08] Frame window filled - picking best frame,26 queued, 0 processed
                  [10:10:24] Frame window filled - picking best frame,27 queued, 0 processed
                  [10:10:39] Frame window filled - picking best frame,28 queued, 0 processed
                  [10:10:57] Frame window filled - picking best frame,29 queued, 0 processed
                  [10:11:15] Frame window filled - picking best frame,30 queued, 0 processed
                  [10:11:29] Frame window filled - picking best frame,31 queued, 0 processed
                  [10:11:43] Frame window filled - picking best frame,32 queued, 0 processed
                  [10:11:58] Frame window filled - picking best frame,33 queued, 0 processed
                  [10:12:01] SysInfo | Cpu: 22.34 %; Disk (C/T): 164808/487036 MB (322228 MB free, 33.84 % used); Memory (C/T): 2895/16308 MB (2151 MB free, 17.75 % used)
                  [10:12:11] Frame window filled - picking best frame,34 queued, 0 processed
                  [10:12:25] Frame window filled - picking best frame,35 queued, 0 processed
                  [10:12:38] Frame window filled - picking best frame,36 queued, 0 processed
                  [10:12:51] Frame window filled - picking best frame,37 queued, 0 processed
                  [10:13:03] Frame window filled - picking best frame,38 queued, 0 processed
                  [10:13:16] Frame window filled - picking best frame,39 queued, 0 processed
                  [10:13:29] Frame window filled - picking best frame,40 queued, 0 processed
                  [10:13:42] Frame window filled - picking best frame,41 queued, 0 processed
                  [10:13:49] Done!
                  [10:14:01] SysInfo | Cpu: 10.57 %; Disk (C/T): 164810/487036 MB (322226 MB free, 33.84 % used); Memory (C/T): 589/16308 MB (4501 MB free, 3.61 % used)
                    Hi Donbert, thanks for reporting it. Can you please share with us the video file that is not working? We are investigating on possible issues related to decoding. You can send me an email at roberto.toldo@3dflow.net
                    Thanks!
