If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Slight Problem When Changing Brush Size in Masquerade
Can you describe step-by-step how to reproduce the issue? thank you
Ciao Andrea,
Thank you for the warm welcome.
When reducing the brush size after using the default setting whilst masking a small window pops up saying "Masquerade has stopped working" or something similar to that.
So, using the default brush for large areas, I then dragged the slider to the left to create a smaller brush, this is when the program stops but it doesn't happen all the time.
As I say, it has only happened a few times and nothing serious happened.
If it does happen again I will try and note exactly what I was doing at the time
Hi All,
Has anyone had a slight problem when changing a brush size in masquerade? Sometimes the program stops working but to be honest, it is is only a small glitch as nothing is lost work-wise
