Zephyr ignoring parts of UV
    Hi Stormy,
    in mur_fenetre_UV_04.obj you have three different meshes. I am not sure if may i have misunderstood your question above (please remember i am not a 3D artist )
    the import failed because in your case you did not have one material for each mesh.
    However, it looks to me that group.local.002 is just a merge of cube.001 and Group.global. I deleted the two objects "cube.001" and "group_global" and reprocessed the UV remap normally.
    here is the result - if you want i can share the zep as well
  • Stormy
    Here is the link to a folder with photos, zep file and last obj meshes used.
    To use Google Drive, you need to use a supported web browser. Learn what a browser is, which browser you use, and how to update to the latest version. Option 1: Find the update for your browser To
  • Stormy
    Great! Do you have a service you can use or shall i open up a space on our server for you?
    I'm uploading everything on Google Drive and I'll send you a download link when it's done!
  • Stormy
    There's 2Go of RAW photos so It will take time to upload but yes I can do this!
    Hi Stormy,
    any chance you could share with me the mesh and project (zep+photos) ? This way is much easier for me to help you
  • Stormy
    Hi, back from weekend, I did everything back and now it seem like Zephyr can't import my mesh, but I can't determine why. Here is the log:
    Yes, that's what i mean!
  • Stormy
    I'm on the 3.702 so I'm triangulating all exports. When you say one single mesh, it mean that it can have two different mesh, merged in a single object, right?
    Make sure you have one single mesh, also no quads (they have been added in the current beta, so if you're on 3.702 only use triangles)
  • Stormy
    okay so now a new problem appear while trying to fix the first one. I export my mesh from blender, it's supposed to be one whole mesh. But when I import it into Zephyr, only the part I made is loaded! :/ The part imported from Zephyr to Blender is ignored..
    I'm not a blender expert but it shouldn't affect it, unless maybe you set the newly created element as parent? If you find the culprit let us know
  • Stormy
    I've merged some element made directly in blender (window cross) and it seems like the join command may affect the overall transformation of the object.
    Hi Stormy,
    did you move the model? you must not translate the model in blender, if that's the case, you should re-open the model in blender and put it back to its original point before exporting it again
