I have tried the Samsung Gear 360. It does not take sharp enough pictures to make good models.
You'll need to find a 360 camera with much better resolution, and preferably one that allows manual adjustments.
Using a 360 camera for capture
As long as you use the raw images or convert the equirectangular image, they will work https://www.youtube.com/watch?v=_SDa...ature=youtu.be
Unfortunately we don't have any specific camera we can suggest. If anything, I'd recommend using DSLRs when possible.Leave a comment:
I was thinking of using a 360 degree capture camera for photogrammetry.
Can such camera be used with 3DF Zephyr? If it can then what would be a good one to use?
Would something like Samsung Gear 360 work?Tags: None
