White Seams on the model
Hi tripledad
The white you are seeing are because there is a slight misalignment with the mesh and the cameras projecting the texture, and the background gets projected onto the surface of the model.
I highly recommend not using a white background with polarisation, as light bounces around the white surfaces and depolarises - Switch out your white background for a black one. Masking, if you haven't already, will help speed up processing times and give better results. Here's a tutorial on the subject: https://www.3dflow.net/technology/do...for-turntable/
Hi Folks,
I tried to build a statuette with about 100 photos. Result looks good but I get always some white seams at the corners.
for my opinion, the pics are good. made the photos with a polarisation filter on the cam.
Any sugestions to prevent it?
Greetings
Ralf1 PhotoTags: None
