My first attempt to create a 3D model of a part of a single house did not brought the desired outcome.
However, I would like to start by giving some information and then I will explain the above issue. All the photographs that I took were with a DJI Phantom Pro V2 and I used the 3DF Zephyr Lite version. Before to start to create a 3D model of a building, I created a 3D model of a field with some ground piles. With almost 100 photographs, which I took them through a flight mission of an application, I can say that the 3D model was pretty good. Nevertheless, I believe that there are some allowances of improvement.
So I would like to ask for your help by giving me advices and guidelines in order to improve my 3D model but at the same time to ameliorate my skills with this software because I really liked it. As a civil engineer I am interested with the potentials that this software provides.
Which parts I have to check in order to change some settings, which will give me the desired outcome?
Which are the characteristics of a good 3D model? What checks I have to do?
What do you advice me to do in order to learn better the software?
Thanks a lot.
Thanks a lot.
