Combining the top and bottom parts of an object
  • CML
    • May 2022
    Is there a workflow for this in 3DF Zephyr Lite or do you need the full version?
    Combining two different image sets of the top and bottom of an object to in the end get a single mesh and texture.
    • 1386
    Hi CML,
    you can indeed combine the two sets together without the use of GCPs or other advanced features.
    Make sure to take enough photos of the subject (there has to be overlap between the two scans, i would suggest for example a third orbit perpendiculare to the first two) and make sure to mask the images using 3DF Masquerade.
    You can find a tutorial here which also includes a sample dataset to try
    Using the masking Tools   Welcome to the 3DF Zephyr tutorial series. This tutorial explains how to automatically create masks in Zephyr and use the 3DF Masquerade tools for image masking. The tool is available in all versions of 3DF … Read More
    and a videotutorial here
    and eventually, a specific advanced tutorial for masking over turntable scenarios
    Masking for turntable   Welcome to the 3DF Zephyr tutorial series. In this recipe, you will learn basic and advanced masking techniques that applies to a turntable scenario in seven steps to Turbocharge your Turntable. While we have already introduced masking with Tutorial #3, this tutorial is … Read More
    • CML
      • May 2022
      Thanks for the quick reply. Seems like the way to go. The excellent masking tool makes turning the object not a big deal.
