Was there a change to dense point cloud editing?
  • levart
    • Mar 2023
    • 18
    Today our office upgraded to the full version of Zephyr after using Lite for some time. I've used the trial of the full version and didn't notice any of the basic functions working differently, but today after upgrading our lab PC with the full version I can no longer see selections on dense point clouds. Normally, after one selects points it looks like this, with selected points in red.Click image for larger version
ID:	8949?That screenshot is from selecting points from the sparse point cloud. If I go to the dense point cloud and make a selection the selection tool says there are points selected, but nothing is highlighted in red. Delete does nothing, but Cut will create a new dense cloud from the invisible "selection."
ID:	8950Does anyone know what would cause this behavior?
    • 690
    Hi levart -
    Thanks for letting us know! This is a bug and will be fixed in the next release.
    • levart
      • Mar 2023
      • 18
      Thanks for your prompt response. I understand you probably can't be specific, but do you know approximately when the next release will be? I have several hundred more objects to model and this bug does severely impact my workflow.
        Hi Levart, sorry for the issue. The patch with this and other minor fixes will be released next week at most.
        If the issue is blocking your work, please note you can install an older version (7.005) while waiting for the patch: https://www.3dflow.net/3df-zephyr-version-archive/
          As an additional note, the bug is only visual. The selected points are deleted, but they are not immediately shown. If you switch the dense point cloud's visibility (off and on), you will see the deleted points.
          • levart
            • Mar 2023
            • 18
            Thanks for the tip. I'll experiment with that workaround and see how it behaves. If I can work around the issue I will do that until the update. Unfortunately, I don't have admin rights to the lab system where the software is installed, so I can't roll back to the last version.
              Hi Levart. Just a quick update to notify you that we have released the patch (v. 7.009).
              Cheers,
              Roberto
