Command line usage
for that, you'll need to look into our C++ SDK, FlowEngine: https://www.3dflow.net/flowengine/
You can use the batching tool (which is a GUI batching tool) in Zephyr, but if you need command line capabilities (or in general, automation capabilities) you probably want FlowEngineLeave a comment:
Command line usage
Hi - is it possible to drive Zephyr from the command line? I need to generated textured models from photosets programmatically without user interaction.
Cheers!Tags: None
