Non-paintable triangles in exported texture
  • jupp2000
    • May 2021
    • 85
    Hi all!
    If i export a model with texture for painting, i always get triangles, that can not be overpainted.
    So that issue is in every textured model.
    Please take a look at the images of the texture paint process in blender.
    (It´s not only Blender, same issue in other painting apps)
    How can I fix that?
    - Zephyr Lite 7.531 - Image has approx. 1,2M Triangles
    • 1377
    Hi jupp,
    it's probably due to how the texture has been wrapped. You should be unwrapping your texture (ideally, manually) when doing postprocessing like this.
    Here's a quick tutorial that I hope helps! https://www.youtube.com/watch?v=rvXBzw2PVMU
    • jupp2000
      • May 2021
      • 85
      but the issue already exist in Zephyr, so i am afraid, a 3rd party unwrapping would not fix it (i already tried that).
      You can see some triangles in Zephyr, that are looking strange. And exactly these triangles have that issue.
      • jupp2000
        • May 2021
        • 85
        Hi jupp,
        I made a quick test in the meantime, and i think, it has something to do with "sharp creases"
        If i totally smooth the model, there are much less non paintable triangles.
        The only one, that remains in blender, has a sharp crease in Zephyr in that area.
        --But of course i loose all of the detail--
          • 1377
          With wrapped textured it's a common workflow that you need to unwrap/rebake the texture for painting I'm afraid. It's the nature of wrapped textured, some triangles will not be paintable until you properly unwrap your mesh. But I see from the discord you managed to do it, glad to hear it
