import mesh and make structured
  • robert langh
    • Jun 2021
    • 39
    Is it still possible with the new update, to edit the exported mesh in Meshlab,
    and import back for texturing?
    The import shows nothing in Zephyr, and the "make structured" gives an error message...
    I export it in .ply, .obj, but cannot re-import them, as in the earlyer version..
    thanks, robert
    Hi Robert,
    yes, the "import mesh with UV map" function is still available, nothing has changed. What do you mean exactly with "the import shows nothing in zephyr"?
    Which error are you getting during make structured?
    Can you post a couple of screnshots maybe? I'm having a bit of troubles understanding your issue, sorry!
    • robert langh
      • Jun 2021
      • 39
      Hi Andrea!
      Sorry for my english, I have a problem, when I export a not textured mesh, to meshlab, where I make some repairing,
      and import back the .ply or obj,
      the name of the unstructured mesh appears, but nothing can be seen on the stage,
      and when I click make it structured, this error happens:
      "some objects were not structured, because an error occured
      check the log for more information"
      [17:04:57] SysInfo | Cpu: 2.53 %; Disk (U/T): 172198/487395 MB (315197 MB free, 35.33 % used); Memory (U/T): 1161/65368 MB (58245 MB free, 1.78 % used)
      [17:06:57] SysInfo | Cpu: 1.05 %; Disk (U/T): 172463/487395 MB (314932 MB free, 35.38 % used); Memory (U/T): 1160/65368 MB (58363 MB free, 1.77 % used)
      [17:07:23] Computing visibility...
      [17:07:23] Computing clusters...
      [17:07:23] Retrieving cluster 1...
      [17:07:23] Preparing camera 'image00001.jpeg'
      [17:07:23] Preparing camera 'image00002.jpeg'
      [17:07:23] Preparing camera 'image00003.jpeg'
      7:23] Preparing camera 'image00344.jpeg'
      [17:07:23] Preparing camera 'image00347.jpeg'
      [17:07:23] Preparing camera 'image00348.jpeg'
      [17:07:23] [CUDA 0] Computing visibility for camera 'image00001.jpeg'
      [17:07:23] [CUDA 0] Computing visibility for camera 'image00002.jpeg'
      [17:07:23] [CUDA 0] Computing visibility for camera 'image00003.jpeg'
      [17:07:23] [CUDA 0] Computing visibility for camera 'image00004.jpeg'
      [17:07:26] [CUDA 0] Computing visibility for camera 'image00343.jpeg'
      [17:07:26] [CUDA 0] Computing visibility for camera 'image00344.jpeg'
      [17:07:26] [CUDA 0] Computing visibility for camera 'image00347.jpeg'
      [17:07:26] [CUDA 0] Computing visibility for camera 'image00348.jpeg'
      [17:07:26] Visibility computation done.
      [17:07:26] Memory used : 1162 MB (Free 58413 MB / Total 65368 MB)
      [17:07:26] Compressing visibility...
      [17:07:26] Done.
      ...I used to do this in the past, with no problem ..
      thanks, r
        Can you please share the full log please? ( you can find hte .flog files directory from the settings).
        Make sure that the mesh hasn't been saved in a different reference system, as that will make it impossible for the structuring to work. Most of hte times the issue is with a georeferenced mesh being save non-georeferenced, or moved in the scene.
        • robert langh
          • Jun 2021
          • 39
          Thanks,
          yes, it was georeferenced, as You write it!
          so it will be not possible edit outside of Zephyr?
          Im sending the .flog file, anyway,
          r
            Hi Robert,
            it's likely that whatever you're doing outside of zephyr is removing or changing the coordinates of the model. Make sure this isn't the case, but I think that's what happened - in that case then it's perfectly normal that the retexurization fails beacuse your object is now in a completely different world position and thus all cameras are failing to reproject.
            Do you need the model to be georeferenced? If so, make sure the third party software supports double precision data, or it won't work.
            If you don't need georeferencing, or if the third party software doesn't support it, you can consider resetting the workspace to a local coordinate system by clicking normalize in the gizmo.
            • robert langh
              • Jun 2021
              • 39
              I understand,
              I dont use georeferences usually, but this time one student in school made some photos about an old monastery,
              which was not enough for the good SFM structure, and we wanted to give a flat ground at least,
              in meshlab, and reimport for the texturing,
              so it was just an idea for saving a poor database, but it will be re-captured in the future better without geolocation!
              Thanks a lot, robert
                You can of course keep the geolocation on, but you must also make sure that the third party software you use supports double precision. Zephyr does support it, but not all software out there does. In any case, simply normalize your workspace after reconstruction if that's the case! happy to help!
                • robert langh
                  • Jun 2021
                  • 39
                  Thank You very much, the normalization is working fine!
                  I have an other question, we are making something like "game developing", where the environment is a forest,
                  with featureless tall trees, and a plain brown ground, which is a playground for BMX riders. I thougt, that the geolocation will help in
                  the SfM process, but the images are unable to orient, with maybe not enough feature points..
                  You write in another post, that the geolocation doesnt play a big role in the orientation, and only has an accuracy of 1 meter.
                  So I was thinking, that the problem is in connection with "robustness", or Matching stage depth, but its not working,
                  even setting everything to Full, or Very high, to Sequential, instead of Global reconstruction...
                  Do You think, that there is something to do, in this case?
                  This is a sample, what is done so far with forest photogrammetry:
                  bests, robert
                    Hi Robert,
                    it's hard to tell exactly what's failing without taking a look at the photos. You can try using GPS as a constraint but if it's just the onboard GPS without an RTK station it can give very bad results - I generally don't recommend that but in the event that many photos gets discarded, it's worth a shot - for this just make sure to enable the constraints in the wizard, then select the camera positions as constraints in the constraints page. This is generally a bad practice (especially without GCPs) but it's possible in some cases that it can save a dataset that's not working.
                    Depending on the photos my first test would be playing with the number of keypoints - if the images are low quality (e.g. lots of ISO speed noise, or blur) sometimes having less keypoints (but more robusts) will work better than having a lot of keypoints, so counter-intuitively, less keypoints might work better. I've seen this in outdoors environments too especially when there's a lot of foliage that moves around due to wind. I don't think this is the case though.
                    If you can share with me the dataset ( support@3dflow.net ) I'll be happy to take a look and give you more tailored advice, sorry for being a bit vague but without the photos I have to do too many assumptions! If the dataset can't be share, can you create at least a sample one in a similar scenario and share that? It doesn't need to be huge as long as I can see the problem in that one too. Thank you!
                    • robert langh
                      • Jun 2021
                      • 39
                      Hi Andrea!
                      I also tried lowering the keypointa quantity, but, You will see in the photos Im sending, that the space is so empty with the trees,
                      that only the pattern of the ground leaves could offer the keypoints, but they are very small. If the sequential order should work for me,
                      I think, that the neighbouring images could be considered as stereoscopic pairs, I assume..
                      We only have a Lite version, and Im unable to find: "enable the constraints in the wizard, then select the camera positions as constraints in the constraints page"
                      I can only find "bounding box method - from cameras"
                      The camera is just an Iphone, we have DSLR with wide angle too, but do you think, that it could solve the problem in this case?
                        Hi Robert!
                        thank you for the email with the dataset!
                        I though you were using the full version - indeed with the lite version you can't use constraints / GCPs - indeed using the GPS constraints wouldn't help anyways, but I thought i'd give it a shot. You might get better results using GCPs (or in any way, to merge "disconnected" projects in case parts of those fail).
                        I couldn't get the full dataset to work, as indeed the nature of vegetation makes it difficult for the reasons I stated in my other post. Especially, if you notice your photos, the further you get the blurrier the images get.
                        You will defintely get better results with a DSLR - consider also using a tripod for better light control. It'll take longer but making sure your photos are sharp will yield much better results.
                        I would also consider shooting at multiple heights to give more parallax to the scene, as some parts are "slented" and that'll show in the texture when there's not enough information. (So whenever you take a step, take not one, but two photos, one at your normal height and another shot e.g. higher, consider using a telescopic pole especially if you want more details on the ground - or maybe add a second pass as a nadiral shot).
                        You can indeed use "sequential" as an additoinal hint to zephyr to speed up the process.
                        I'm not sure what you mean with "stereoscopic cameras" in this case since you only have one device - if you have more physical devices at a known distance you can use that as as constraint (in the full version only though) which will also yield a rigid transformation, but your issue with this dataset I'm afraid lies in the photos themselves.
                        I hope this helps! If you take another pass with the DSLR and still need help feel free to share them with me and I'll be happy to take a look at those again.
                        • robert langh
                          • Jun 2021
                          • 39
                          Thank You for your help, and I will sign back, if the DSLR+tripod system works!
                          bests, robert
