orthophoto export
  • jose muņoz
    Thank you very much for your answers.
    regards
    Hi Jose,
    - its not "soil sample distance" but "ground sample distance" - https://www.3dflow.net/ground-sampli...ce-calculator/ - is it mistranslated ?
    - you must select the correct DSM option in order for zephyr to compute it. Select it accordingly to your scene, this way zephyr will use different algorithms and parameters to remove, for example, buildings.
    - world file and autocad script can be generated when needed. The world file is used to georeference the image, if needed. The autocad script will help you import it into Autocad.
  • jose muņoz
    started a topic orthophoto export
    orthophoto export
    Hello, I am developing this software in Chile. But I have some doubts regarding the export of orthophotos. In the configuration I can generate a DSM, which can be presented with different alternatives. What does each one refer to? (I attach a photo) Also, what does it mean with soil sample distance? What do you mean by the world file? What do you mean by the autocad script? Can I load the orthophoto in autocad from the script? regards
