select rect says drag a rectangle but scene rotates instead
  • DBenz
    • May 2025
    • 10
    I am in ortho view, though no indicator says ortho, I am using the select option lower right, left one says rect, and says click for the top left of a rectangle, I do so and immediately get a green dot appear and the scene rotates and becomes non ortho.
    I try again resetting with 9 as top and 5 as ortho (as set up to match Agisoft for my sanity) and same happens.,
    happens whether I am in ortho or not.
    the selection rect option rotates the scene instead.
    DBenz
    DBenz
    When using the selection tool, right click will pause the tool and enable rotation (if you are in orbit or pivot nav mode, not WASD) -- Click resume to re-enable the selection tool.
    • DBenz
      • May 2025
      • 10
      Hi, thanks I will give that a try.
      DBenz
