If you are dissatisfied with your results from photographs using 3DF Zephyr, please feel free to share the photographs with us so we can give you some in-depth feedback on how to improve your image acquisition and subsequently the 3D results you will get!
Are the letters blurry on your cookie package box in any of the photographs you took? If not, it might be that the cameras in your scene have not oriented correctly and need some adjustment for a better outcome. There are a lot of variables to consider, so sharing the photographs and any Zephyr project files (.ZEP) which you are having trouble with will help inform our response
You can certainly combine third party laser scans with photogrammetry in Zephyr, however, this functionality is not available in the LITE/FREE versions of 3DF Zephyr, only the full version (either monthly subscription or a perpetual license) - If you want to try the full version of 3DF Zephyr you can do so by following this link and filling in the application form: https://www.3dflow.net/3df-zephyr-ev...download-page/
It seems strange that STL is the output data format for the 3D laser scanner - STL is more of a finishing format than a format you want to be working with. STL files don't have scale information and their units are arbitrary. There are a lot of different laser scanning systems available, and a lot of different formats Zephyr and import/export (including STL):
Here is a list of compatible mesh import file types:
*.ply
*.dp
*.ive
*.osgb
*.fbx
*.x3a
*.las
*.ptx
*.txt
*.obj
*.e57
*.collada
*.xml
*.dae
*.stl
Points (*.pts)
Coordinates (*.xyz)
FARO Laser Scanner (*.fls)
FARO Workspace (*.fws)
Zoller + Frohlich Scan (*.zfs)
*.rdb
Riegl Scan (*.rdbx)
Dot Product Scan (*.dp)
*.ive
*.osgb
*.fbx
X3a Archive files (*.x3a)
I hope this is helpful!
