If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Sorry it took me a while to respond - I've been away for a little while but back now
STL is definitely an export option with 3DF Zephyr Lite - I recommend you look into Autodesk MeshMixer as it's a program tailored to 3D print preparation - I use it in conjunction with 3DF Zephyr as a kind of checking/fixup tool :-)
thank you cam3d for the response.. another question if you don't mind, can you save to stl with the lite version ? what i am looking to do is make 3d models that I can 3d print on my 3d printer. I make things from wire and other material and would like to replicate in plastic.
anyone know how to change .zep files into obj or stl files. i'm thinking about the lite version and want to see how they work out with 3d printing. thanks in advance.
